It is currently Wed Aug 13, 2025 6:44 am
 Post subject: Band saw and Plexiglass
PostPosted: Tue Feb 02, 2010 12:34 pm
First name: Richard
Last Name: Sprouse
City: Spartanburg
State: SC
Zip/Postal Code: 29302
I would like to cut out some plexiglass templates. The plexiglass is about 1/4". Will this cause problems with the blade? Should I change to an old blade that I keep as a spare?
Richard
PostPosted: Tue Feb 02, 2010 12:49 pm
Last Name: Lloyd
I use polycarbonates for jig material and the band saw and router don't appears to have issues with cuttting. There are some many plexiglas products I can't venture to answer your question and can only offer the following wed site.
http://www.plexiglas.com/expert/
Michael Lloyd
PostPosted: Tue Feb 02, 2010 12:53 pm
Yeper plexiglass is brittel and will often fracture when cut or machined. Polycarbonates like Lexan are better suited for cut and machined parts.
PostPosted: Tue Feb 02, 2010 1:07 pm
I recommend a bi-metal blade for cutting plexiglass. A 1/4" - 10 - 14 tooth variable blade works fine.
PostPosted: Tue Feb 02, 2010 1:18 pm
Richard
YES!
PostPosted: Tue Feb 02, 2010 4:35 pm
nah, switch to your new blade. old dull blades generate too much heat -always your enemy when cutting plastic. select a blade pitch that places at least 2 teeth into the cut (material thickness), blow some air on it and cut away.
Users browsing this forum: doncaparker and 23 guests
